1, Any good supplier will have dial string. It's a fiddly job but very rewarding. Lots of patience and coffee.
2, I have a used part in stock.
3, I don't know what this is but held up against 4, it seems that someone tried to lubricate and used the wrong agent.
Isopropanol (tapehead cleaner, carburettor alcohol or whatever you prefer to call it) will remove most, I'm sure.
If you need to lubricate anything, use silicone grease or sewing machine oil, never motoroil, "hobby oil" or WD40.
4, Probably a seized tuning capacitor, same as the above.
5, For those who stare at a Beomaster 901 and wondered where the headphone socket is - it's at the back !
This suggests that the connecting of a headphone is more or less permanently.
The headphone output is at speaker level so no problem in using normal 8 ohm headphones.
Having said that; There are two different Beomaster 901's, one type has two speaker outputs (1 pair), the other has 4 (2 pairs).
With headphones connected permanently, the potential load of the
amplifier will be too high if at the same time using 4 ohm speakers, one pair or maybe even 2 pairs.
If using 8 ohm speakers, I see no problem in using normal 8 ohm headphones.
If using 4 ohm speakers, the speakers will have to be disconnected
or the headphones will have to be of a higher impedance.
Since the Beomaster 901 has no speaker switches, using the latter was what B&O suggested.
