Latest post 05-04-2009 8:21 AM by avus17. 16 replies.
Page 1 of 1 (17 items)
  • 01-11-2008 2:04 AM
    BACKLIGHT ON BV7
    Can somebody tell me what is a factory setting for backlight on BV7 32" type 9311 and how to increase the backlight? Is 70 correct setting?
  • 01-11-2008 3:40 PM In reply to
    Re: BACKLIGHT ON BV7
    Sorry - don't know! The service manual is on site but I can't find the answer!! The picture settings are there but I cannot say back light. Just brilliance.
  • 01-11-2008 4:55 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    I just checked the service menu of my BV7 (MKII), but I can't find how to adjust the backlight, so I can't tell you what the initial setting is, as I never changed it. Could you tell me in what menu-page you change that setting, I will check it for you?
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 01-13-2008 2:10 AM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    tom:
    He mean the "Scaler contrast" setting...
    BL8000 MkII Black
  • 01-13-2008 4:22 AM In reply to
    In the manual I have, scaler contrast has a value of 136
  • 01-14-2008 1:40 AM In reply to
    Hi Peter,
    thank you for the answer at the BW forum. My factory setings for BV7 32" type 9311 in the Scaler menu 1 are the same:
    brightness 15, colour 23, contrast 50 and scaler contrast 136 as it should be. But I have problems that my TV dimes dark scenes of the films (cable TV) and DVDs very much and the picture gets too dark. This is quite annoying at is happens so quickly (from dark to light and back).
    I have contacted Roger who told me that I should try to increase the contrast in the Scaler menu 1 from 50 to 62 but this did not solve the problem. I have also tryed to turn off the film mode but nothing changed. He also told me that the cause could be a defect light sensor.  I had my TV for inspection at the B&O service and averything was OK.
    Do you have any idea if there were any problems with BV7 32" type 9311 LCD panels? I have calso hecked the menu "Monitor information" and there are two errors listed. Is this normal? As they are listed with numbers and letters I have no idea what this could be. If you have some knowledge about this matter I can communicate the error descriptions.
    Thank you for any help in advance.
    Vid
  • 01-14-2008 2:15 AM In reply to
    Have sent you a PM with some information.
  • 01-14-2008 12:57 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Hi Peter
    It happens exactly to me with my BV7-32 MK1 type 9311. Can you send me that information too?
    Quim
  • 05-03-2009 6:13 AM In reply to
    have same problem on my beovision 7, was there a fix to this problem ?
  • 05-03-2009 6:46 AM In reply to
    • beoaus
    • Melbourne, Australia
    • Posts 445
    What I have used...
    Existing Setting 10/07/2007
    Scaler Menu 1
    Brightness:  17
    Colour:   23
    Contrast:  42
    Scaler Contrast: 136
    BV 7-40 Org: Scaler menu 1.
    Brightness: 16
    Color: 23
    contrast: 47
    Scaler contrast: 136
    (Backlight: 65%)
    1st tweak settings:
    Brightness: 17
    Color: 24
    contrast: 55
    Newest: (best)
    Brightness: 16
    Color: 23
    contrast: 75
    Scaler contrast: 153
    Beoaus..
  • 05-03-2009 8:57 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    avus17:
    Hi Peter,
    Vid
    I have a similar issue with my BV4/BS3. I always assumed it was the Auto contrast light sensor acting up. In fact I think I disconnected it once ( IR Eye puck ) and it seems that it behaved a little better. Can anyone else confirm that this can be an issue?
    -Michael
  • 05-03-2009 9:30 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    If the room is small, with no light and white walls, the autocontrast eye can be fooled by the light of the TV :
    Bright scene : the electronic eye sees a lit room, so it turns the backlight up to the max (as by increasing the backlight you increase the room light)
    Dark scene : the electronic eye sees a dark room, so it lowers the backlight to the min (reverse as previous point)
    So, there are different solutions :
    a. Try with an ambiant light
    b. Try with autocontrast off
    c. Try with black walls
    d. Try with a larger room
  • 05-04-2009 2:05 AM In reply to
    I had the same problem with my BV7 32" type 9311. The problem is, when the HD module is built in additionally, almost every service department installs a new software. BV7 32"" type 9311 does not have any backlighting. But with new software this option appears automatically and is set to on. If backlight is set to on, sudden dimming happens at some time what is very disturbing when watching TV.
    So if you want to solve the problem you must turn the backlighting in the service menue to off! Then BV7 works perfectly.
    Press menu+00+GO and find the backlighting in menu and set it to off.
    This will help for sure and is the only solution.
  • 05-04-2009 2:49 AM In reply to
    avus17 you where spot on ! I turned backlight off, and the TV works perfect.
    thx !
  • 05-04-2009 4:31 AM In reply to
    Thank good:D Have you bought this TV used? How much did you pay for?
  • 05-04-2009 5:17 AM In reply to
    yes i bought it used, payed 25.000 kr (2500£) incl beolab 7-1 and floorstand and HD kit installed (therefore the error with backlight)
  • 05-04-2009 8:21 AM In reply to
    hopefully u will be satisfied now with your TV was it mint condition. I have bought my (the same set) 2 years ago for 5.800,-€
