Latest post 04-26-2007 5:40 AM by MoglesMac. 5 replies.
Page 1 of 1 (6 items)
  • 04-25-2007 6:06 PM
    BeoSystem 5500
    First of all, been reading thru this site alot and it looks really good and it have been very helpful for me.
    Im a very new poud owner of a BeoSystem 5500 + MCP 5500 and i have a couple of questionmarks if anyone can answer them:
    1. Is it really possible to use a Beolink 5000 to control a BeoSystem 5500 coz when I try i only get the "no contact" message.
    But when i change the Beolink to 1-way-communication it works ok and i can control the most "basic" functions.
    2. Can you switch to AUX on the Beomaster 5500 with Beolink 5000? (no button, gotta be a combination of buttons).
    3. I think sadly i have a problem with the DataLink on the Beogram CD 5500 coz when i start a CD I get no response from the Beomaster but if i personally switch to CD via Beolink or MCP i get sound from CD. Is that maybe a "known" problem? Something that maybe can be easly fixed? Im aiming tho for getting it repaired but i just wanted to know if it was a "known" problem. I have also ruled out the specific datalink connection since i have tested to plug in CD in TAPE2/AUX datalink too with no luck.
    Hope you guys can help me out abit :)
    MoglesMac
    Sweden
  • 04-25-2007 7:20 PM In reply to
    Re: BeoSystem 5500
    The Beolink 5000 does not work in 2 way in my experience. Possibly the later 5500s do, but certainly mine does not!
    Not sure about Aux - not in the manual!!
    As far as the CD is concerned, check the DIN plug has all 7 pins in it. Sometimes two are unscrewed.
    Re: BeoSystem 5500
    Can't help you with 1. Others here will know.
    On 2 - try pressing first SHIFT on the back, and then ATAPE - that should get you AUX
    On 3 - have you checked whether any of the pins are bent, or broken? Could be a faulty cable.
  • 04-25-2007 7:23 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: BeoSystem 5500
    Welcome to BeoWorld Smile
    Congratulations with your Beosystem 5500 .
    Regarding control by Beolink 5000,
    unfortunately not in 2-way mode, only in 1-way mode.
    The 2-way of the MCP (5500) is different from Beolink 5000/7000.
    Having said that, i'm somewhat puzzled about my Beomaster 6500
    being able to cope (2-way) with MCP 6500, as well as Beolink 5000 and Beolink 7000....
    AUX on Beomaster : SHIFT +  RADIO
    (SHIFT + source-button gives acces to several other sources)
    Regarding the Datalink-issue, i don't know,
    but i'm pretty sure that fellow members can help you with that Smile
  • 04-25-2007 7:59 PM In reply to
    Re: BeoSystem 5500
    Ignace is right. I gave you the instruction for selecting Tape 2 with the Beolink 5000.
    SHIFT + RADIO = AUX
    SHIFT + ATAPE = TAPE 2
  • 04-26-2007 5:40 AM In reply to
    Re: BeoSystem 5500
    Thanx all for the very good input, my hair was turning gray out of dispair for not getting the Beolink 5000 to work in 2-way-communication but now i know why hehe and the SHIFT + RADIO works as a treat... look and behold, the lovely AUX :)
    About the CD-problem i will check the DIN-cable and pins on it as soon i get a chance, i need help with lifting and moving it around.
    Again.... huge thanx for all the answers :)
    MoglesMac
    Sweden
