Latest post 01-10-2008 4:54 AM by Graham1982. 10 replies.
Page 1 of 1 (11 items)
  • 01-09-2008 10:52 AM
    Bang and Olufsen B&O BeoVox Cona Passive Subwoofer
    Would this be any good for or indeed is it compatible with an Avant to build a pro-logic system?
    Graham
  • 01-09-2008 11:11 AM In reply to
    • LarsJensen
    • Not Ranked
    • Joined on 04-25-2007
    • Copenhagen, Denmark
    • Posts 65
    Re: Bang and Olufsen B&O BeoVox Cona Passive Subwoofer
    I don't think I would use in a prologic setup. First your front speakers shuold be passive speakers driven by the same amp as your Cona since the cut can not be done within the TV in a prologic system (if I remember right). Second I think you would need two amps. One per channel. The prologic outputs left and right on two connectors but the amp only has one powerlink connentor. Even then I would only do it if my front speakers where CX speakers. And even then I don't think I would do it at all.
    /Lars
  • 01-09-2008 12:54 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    You could do it, but the cost incurred would be higher than getting an Avant with a Dolby Digital board, and the results no way near as good.
    The Cona would require a separate amplifier, and depending in your main speakers, may not give much of an improvement...
     Weekly top artists:
  • 01-09-2008 1:01 PM In reply to
    Sorry, I meant to say that my Avant is Dolby enabled but having looked at the proper  sub for this system it is way out of my price range for the min. Could anyone give me some basic prices (lowest) of a setup with b&o speakers - Ebay etc?
    Graham
    PS I mean a ball park estimate!
  • 01-09-2008 2:53 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Graham, the main problem is that you need Active speakers. This will mean you would need several ML/MCL converters to use as amps. To power different sets of Passive speakes.
    CraigSmile
  • 01-09-2008 4:30 PM In reply to
    • LarsJensen
    • Not Ranked
    • Posts 65
    If your Avant has Dolby Digital (With a powerlink socket for a sub) you could use a Cona with a fair result.
    With the Cona connected to the Avants digital board the cut-off filtering is not taking place in the Cona. Put a MCL 2P to just run the Cona and it will performe okay.
    And for the price on speakers do you mean a complete setup with front, rear and sub?
     /Lars
  • 01-09-2008 4:34 PM In reply to
    • Alex
    • Posts 2,990
    I wouldn't want to use an MCL2P to drive a Cona, or any subwoofer for that matter!
     Weekly top artists:
  • 01-09-2008 5:05 PM In reply to
    • LarsJensen
    • Not Ranked
    • Posts 65
    What would you use to drive it then?
  • 01-09-2008 6:35 PM In reply to
    You could use a Beolab 200 (150W monoblock amplifier).  Complete with Powerlink input.  I have a pair that I use to drive my "proper" hi-fi speakers when I hitch them up to my BC9500.
    Lawrence
    Lawrence
  • 01-10-2008 3:26 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    See this thread http://forum.beoworld.org/forums/thread/76526.aspx for alternatives to Beolab 2.
    I use a 100 € non B&O Sub connect via DIN/RCA cable to my BV 3-32 DD module.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-10-2008 4:54 AM In reply to
    Hi:
    Yes, I mean a complete setup with sub and all of that. To be honest I am not that great at picking out dfferent quality speakers in high end systems. I mean, I can clearly tell the difference between a pair of plasticy computer speakers or cheap integrated system speakers. Thus I guess I am just looking for a resonably modern (or of the same age as my Avant) set of B&O speakers that are meant for the purpose. Namely plug straight into the back of my TV without having to "drive" them with anything else making it a lash up.
    Thanks to everyone who has responded so far...
