Latest post 03-27-2008 7:39 PM by B&Ola. 7 replies.
Page 1 of 1 (8 items)
  • 01-08-2008 8:17 AM
    • BEOfreak
    • Not Ranked
    • Joined on 04-17-2007
    • Odense, Denmark
    • Posts 63
    BeoLink Pass. vs. ML/MCL conv.
    Are there any difference between the BeoLink Passive box (type 1656) and the ML/MCL Convertor box (type 1651)?
    Rasmus
    Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
  • 01-08-2008 11:41 AM In reply to
    • BeoLad
    • Not Ranked
    • Joined on 07-23-2007
    • West Midlands
    • Posts 37
    Re: BeoLink Pass. vs. ML/MCL conv.
    Yes there is, the passive has been designed for use in a beolink system to utilise passive lous speakers in a link room  or outdoors. The Ml/MCL you would use to connect passive loud speakers direct to one of the audio systems for example a 3200/3000, as the audio does not have in-built amplification
    hope this helps you out
  • 01-09-2008 2:57 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    This is from the specs, but they look just the same.... with IR eye and ML used as Beolink Passive for Link Rooms, without the eye and using the powerlink connection as an amplifier. So to me they are interchangable...
    Can anybody confirm this?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-09-2008 6:02 AM In reply to
    Yes indeed,the ML/MCL converter and Passive are in fact the same beast,and very versatile too! Simply connecting a ML sensor to the unit,converts it to a Beolink Passive,where you have independant volume,bass and treble control.Without the sensor,the unit can be used as a slave amplifier,say to drive passive speakers from Powerlink connections.Also of course,the unit can be used to convert ML to MCL,and vice versa,eg.when installing current product in a house wired for MCL using passive speakers!
    A clever box of tricks?
    Regards,
    Nick
  • 01-09-2008 6:55 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    Thank you all for your replies. I'm definitely going to by such a versatile box.
    Regards,
    Rasmus
  • 03-25-2008 3:36 PM In reply to
    Picking up an old thread...
    I tried to use a Beolink Passive with a 7-pin Audio Aux Link cable connected to my BS3000.
    It worked fine but does anyone know if it's safe to use this cable?
    The manual sais that it should be a 8-pin Powerlink and the 8th pin in the center of the Power Link is for Power failure/Overload so this is what's missing.
  • 03-25-2008 5:20 PM In reply to
    B&Ola:
    Yes it works fine, your data link cable has all the connections thats needed,
  • 03-27-2008 7:39 PM In reply to
    Thanks for the replay!
