1st March February 2012
Latest post 01-10-2008 4:23 AM by joeyboygolf. 16 replies.
01-06-2008 5:12 PM
beo4life
- Joined on 04-16-2007
- Ely
- Posts 64
Connecting Beolab 6000's to a Panasonic TH42PX70
My understanding is that because the beolabs are active and the sound output of the tv is already amplified, i cant just connect them up and go. Is this true? Is there a work around? or am i talking out of my backside and i just need to plug in and go because the speakers have far more intelligence than me and can adapt.
Regards Brett
beolife
- Joined on 04-19-2007
- Posts 163
Re: Connecting Beolab 6000's to a Panasonic TH42PX70
The panasonic does have line level outputs which can be used for a stereo or something, with the correct adaptor to Din plugs so you would need to go through a Beosound or beosystem in order to control the level to the Beolabs as they do not have a preamp inside them . Simon
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
Brett...........you asked me this question and I told you the answer..........did you not believe me???? Kids........huh!!!
beo4life
- Ely
- Posts 64
I'll just have to hook up the beovox 5000 then :-)
Regards Brett
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
joeyboygolf: Brett...........you asked me this question and I told you the answer..........did you not believe me???? Kids........huh!!!
Brilliant.   Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
beo4life
- Ely
- Posts 64
Come on someone. Prove the old git is wrong!! We've got 4 pairs of these and i want to hook at least one pair up to my new tv.
Regards Brett
symmes
- Joined on 04-21-2007
- Freedonia
- Posts 290
1, If you have phono outputs on the tv, you can hook rca cables straight into the 6000s (separate line jack on us model) and control them with the tv or cable box. You might need to switch them off with a switched outlet. 2. If you use speaker outs, you need a speaker-level output to line-level output converter (inexpensive), and then do as above. Not difficult and works nicely.
Alex
- Bath & Cardiff, UK
- Posts 2,990
symmes:1, If you have phono outputs on the tv, you can hook rca cables straight into the 6000s (separate line jack on us model) and control them with the tv or cable box. You might need to switch them off with a switched outlet.
All BL6000s have RCA connections I believe...
Weekly top artists:
kallasr
- Willich, NRW, Germany
- Posts 1,077
symmes: 1, If you have phono outputs on the tv, you can hook rca cables straight into the 6000s (separate line jack on us model) and control them with the tv or cable box. You might need to switch them off with a switched outlet.
There are: RCA phono type connectors (L, R) (1 set rear) http://www.hdtvtest.co.uk/Panasonic-TH42PX70/Specification.php
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
beo4life
- Ely
- Posts 64
I do have a beocenter 2500 floating about. Can i connect to the tv via the auxlink and control the volume through the 2500 with the beolink i assume i just need to butcher an auxlink lead and connect the correct two wires to the tv?
Regards Brett
joeyboygolf
- Posts 3,252
Now then, now then. It's Dad here! I've seen the TV 'cos he's left the bloody thing in my lounge while he get's permission from his SWMBO to have it in his house! The set has 2 outputs as far as I can see from the destruction manual and they are both RCA socketed. Output 1 is for extension passive speakers and the amp in the TV has 10wpc output. So this output is NOT suitable for connection to Lab6000's. It would drive Vox 5000 but would she approve?? Output 2 is 0.5v and is designed for connection to an amplifier. However, as far as I can tell it is NOT volume controlled. So again, is NOT suitable for connection to Lab6000's unless you want them to play at half volume all the time!! Output 2 would feed the AUX input of the BC2500 and allow the use of 6000's via powerlink but you then have the 2 remote (3 with Sky+)situation which I know that Brett want's to avoid. Is everybody following me so far??? Good, then over to you Brett! In case anybody does not know, Brett is my son!!! Yes I know I should dis-own him for buying a Panasonic but his Mum still loves him and she won't let me.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
As I'm knowingly stepping into a domestic I'm wearing my tin hat B&O themsleves used to sell "adapter" leads that included resistor pads within the Din plugs to attenuate normal "speaker out" levels to "line in" levels. These were in order to use things like BM5000 with active speakers. Its obviously a bit of compromise but I see no reason why you couldn't lash up something similar.
beo4life
- Ely
- Posts 64
From your comments on other topics, i'm sure you'd disown me if i paid 7k for a BV7-40! So £660 for a Th42PX70 with a 3 year warranty is a steal. I'll repeat what you said last night, from your very own mouth, "I won't watch the panasonic when your not here, cos i'll want one" Looks like i'll go with the beovox 5000's and lock the door so the bread knife can't see'em Brett
Regards Brett
joeyboygolf
- Posts 3,252
From our initial look last evening the PQ using the inbuilt DVB-T was excellent. I'll reserve proper judgement until we watch it tonight when Spurs will undoubtably lose. Watch this space for a report tomorrow but £660 with 3 year warranty does seem incredibly good value!
Puncher
- Posts 9,588
joeyboygolf: From our initial look last evening the PQ using the inbuilt DVB-T was excellent. I'll reserve proper judgement until we watch it tonight when Spurs will undoubtably lose. Watch this space for a report tomorrow but £660 with 3 year warranty does seem incredibly good value!
Surely you'd rather pay £7.5K so that you have full link capabilities!
joeyboygolf
- Posts 3,252
Well, once we adjusted the contrast so that it didn't appear that we were watching some bizarre animated cartoon, the PQ was excellent, especially on close up shots with relatively small movement. Distance shots did show up some digital artefacts which I found uncomfortable compared to the Avant. Or maybe it was the size of the screen which means that your eyes have to move more to take in the view, I'm not sure. Overall, I'm not sure. He'll be taking it home at the weekend. Will I be sorry to see it go? I don't think so, but that is more to do with it's current temporary position rather than the quality of the set. What is undeniable is that the value for money is exceptional compared to the equivalent B&O notwithstanding the interconnectability and remote issues. Oh! Forgot to mention that Spurs- Arsenal was a 1-1 draw but since I'm not a fan of either team, most importantly, my wife had £10 on Spurs to win, so that went out the window!!!
Page 1 of 1 (17 items)
