Latest post 01-06-2008 4:27 PM by beolife. 4 replies.
Page 1 of 1 (5 items)
  • 01-06-2008 9:08 AM
    Beolink sound problem
    Hi
    I have a BM7000 connected by converter box 1611 to ML connected to my avant, I can play CD, Radio etc on the avant no problems but I cannot hear the Sky that is connected to the Avant on the BM7000 in the other room.
    Any thoughts
    Regards Simon
    PS just to add I have got the sky box connected by scart to the avant
  • 01-06-2008 12:10 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beolink sound problem
    Is the box set up using it as a decoder on the first and only tv channel (channel tv 1: decoder=yes)
    this way, if you press tv it using the sky box?
    this is how my set top box is configured and i can use link tv on my beolab 3500 to listen to the tv station.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-06-2008 12:37 PM In reply to
    Hi Kallasr
    The sky box is set up as Sat/STB on the avant but when press sat in the room with the BM7000 I cannot hear the sat.
  • 01-06-2008 12:45 PM In reply to
    It will probably be the option setting - the TV and Beomaster should both be option 2 - at a guess they are option 1.
  • 01-06-2008 4:27 PM In reply to
    Thanks Peter
    Checked option setting's again & it cured the problem, I must of accidently hit 1 instead of 2 when playing around with the system ( long story about the Beosysetm 2 etc).
    thanks again guys
    Simon
