Interesting aside! The B&O cartridges are set so that the diamond, which is square, is set so that the diamond tracks with the parallel surfaces parallel to the grooves. The Soundsmith cartridge is set at 45 degrees to this so that the edges are next to the grooves. Not a lot of people know this.....
Obviously the part of the diamond that tracks the groove is the cut part which is heavily sculptured on both.
