Latest post 01-06-2008 9:52 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 01-05-2008 6:34 PM
    Replacement keypad for Beocenter 2300?
    Hello,
    I recently purchased a Beocenter 2300 on ebay, and upon receiving it noticed that the "LOAD" key on the keypad had been worn/scratched out. Are replacement keypads readily available? The local B&O authorized service was less than helpful in the matter, so I need to source the keypad myself and then deliver it to them for installation.
    Regards,
    Antti
  • 01-06-2008 3:59 AM In reply to
    Re: Replacement keypad for Beocenter 2300?
    The replacement buttons should still be available as spare parts.
    According to the service manual on this site the part number is 2776226. I suggest that you check this with another dealer as the part number may be out of date.
    Regards Graham
  • 01-06-2008 6:21 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    ... as the part number may be out of date
    Yes, it is 2776248 now!
  • 01-06-2008 9:40 AM In reply to
    Thank you for the part number. Are there any online dealers that might have the part available, or do I have to go through "official" B&O channels? I think I might as well order the part from where it is most readily available, instead of trying to track it down here in Finland.
  • 01-06-2008 9:52 AM In reply to
    You have no option but to order through your B&O dealer who can order it from Struer.
    Regards Graham
