Latest post 01-08-2008 1:23 PM by ®. 11 replies.
Page 1 of 1 (12 items)
  • 01-05-2008 8:42 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Fault: BeoSound 4 shutting down.
    After approx 15 mins of playing a CD my Beosound 4 died with nothing displayed on the screen. Not even the power light was on. I unplugged it for 5 mins and it came back to life. I will report back....
  • 01-05-2008 8:43 AM In reply to
    • UK
    • Posts 970
    Re: Fault: BeoSound 4 shutting down.
    Its happened again when listening to A.AUX. Ick!
  • 01-05-2008 8:59 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Richard, is it still under warranty? If so I would get straight on the phone to you dealers.
    CraigSmile
  • 01-05-2008 9:26 AM In reply to
    • UK
    • Posts 970
    Sure is. Looks like I will have to disconnect it and return it. What a pain.
  • 01-05-2008 10:08 AM In reply to
    • UK
    • Posts 970
    It took 23 mins to shut down this time. The glass slides up before the screen goes blank. If I press CD on the BoeSound 4 the display shows the CD name but the CD doesn't spin. I have to press power OFF then CD for it to start again.
  • 01-05-2008 10:23 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    We chose to buy a bs4 with the plan to keep it for many years, but with the issues bs4 has, i'm worried it won't last. Luckily after a few exchanges under warranty our current unit hasn't faltered.  Why are there so many issues with this model?
  • 01-06-2008 4:37 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    What do you mean issues? There aren't really any 'issues' with the BeoSound 4.
    No product will ever have 100% reliability rate, there will always be a few units produced with issues. As far as I'm aware, the BeoSound 4 doesn't have a 'high' failure rate. I always tend to think o them as being quite robust and reliable actually...
     Weekly top artists:
  • 01-06-2008 11:24 AM In reply to
    • UK
    • Posts 970
    I dropped mine off at the dealers yesterday for the service guys to test & fix.
  • 01-06-2008 6:46 PM In reply to
    • Dave
    • Posts 2,328
    Alex:
    Do you own one? We had plenty of issues, and i continue to read in forums about bs4 failing, and having some sort of problem
  • 01-07-2008 5:50 AM In reply to
    • Alex
    • Posts 2,990
    Dave:
    No, I don't own one, but I have heard nothing about build quality issues with the BeoSound 4. If there were any, I would have heard about them...
     Weekly top artists:
  • 01-07-2008 9:13 AM In reply to
    • UK
    • Posts 970
    I've read about BS4 faults on this forum, I have to agree with Dave on this one.
  • 01-08-2008 1:23 PM In reply to
    • UK
    • Posts 970
    My BS4 isn't shutting down at the service centre. It appears that its a problem external to the BS4.
    Suspicion is pointing towards the Apple Airport Express connected to the A.AUX of the BS4 for listening iTunes causing problems or maybe a masterlink problem. ????
    to be continued
