Thanks both for your reply
Peter the deck came with the 5 pin din as a standard factory fit i am not sure if it was part of a system or not.
It is as new and in the box so for £1.99 i grabbed it quick!! and it sounds great on the BC9500 playing J M Jarre.
Looks like i will have to save up a few more pennys then?
Cheers
Mark
