Latest post 01-09-2008 1:51 AM by yachadm. 4 replies.
Page 1 of 1 (5 items)
  • 01-04-2008 11:20 AM
    Parts for a beocenter 9500
    I cant find any sorse for parts and theres only one B&O store in the state.  Help!!!!   I'm looking for the drive belts for the door moters, the plastic channels that hold the glass top & bottem, a clip for the prop rod and a new battery.
    P.S.  I had problums with both doors not oppening so I oppend it and found 3 of the 4 strings off.  I got all 3 back on (a big pain in the butt) the tape door works well but the cd door will only work when in the servise position.  It seems stiff and slow wen it does oppen and some times wont oppen all the way.   Any Ideas?
    Mike
  • 01-04-2008 11:30 AM In reply to
    Re: Parts for a beocenter 9500
    where in the states are you located?
    i have had great service from Benny @ 770-642-6259 (atlanta, ga)...
    he was recommeded by the b&o store there as he is the regional repairer.
    he was able to source what i needed for my 9300.
    highly recommended...
    • B&o bottle opener
  • 01-04-2008 11:33 AM In reply to
    also... w/ regards to the sticky door...
    make sure that the tabs that slide in the rails are straight and true! they tend to get out of whack after force has been applied to them. they are relatively delicate -a little warm water and gentle coaxing should re-align them -that fixed mine.
    • B&o bottle opener
  • 01-04-2008 12:00 PM In reply to
    I'm in Maryland.  I'm not what tabs your refering to but I think they are ok.  I'm pretty shure I dont want to take the strings off again if I dont absolutly haft to. NOT A FUN JOB.
    Thanks guys
    Mike
  • 01-09-2008 1:51 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    3 good sources for B&O parts and repair in the USA:
    Paul - Atlantic Systems MA  781-826-8760
    Larry - Approved Audio CT  860-567-5801 repair@approvedaudioservice.com
    Chris Lewis - Pyramid Audio TX  512-458-8292  tech@pyramid-audio.com
    All 3 are recommended highly
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
