Latest post 01-05-2008 2:37 PM by jk1002. 5 replies.
Page 1 of 1 (6 items)
  • 01-03-2008 9:16 AM
    Projectors compatible with BnO
    Hi there, im working on setting up my front room to be my new cinema.. & was wondering wether anyone knows which projector & screen will work with my "projector ready" 7:32, ive been told it will intergrate with my Lutron lighting system so I guess im arf way there.. any help will be glady accepted.
    Life-is all about CHOICE....
  • 01-03-2008 10:14 AM In reply to
    • Jeuke
    • Not Ranked
    • Joined on 12-29-2007
    • Posts 41
    Re: Projectors compatible with BnO
    Hey woodmanta, can you tell me which BV 7 32 you have MK1 MKII or MKIII?
    The projectors which can be controlled are Samsung SPH 700 and SIM 2 HT 300....
    Good luck with set-up
    Gr
     Jeuke
  • 01-03-2008 5:01 PM In reply to
    Hi Jeuk.
    its the latest version MkIII.. why???
  • 01-03-2008 5:07 PM In reply to
    Hey there again.. Sorry, forgot to say THANKS...
    ps do u have any experience in setting up a Home Cine,a setup with BV732??
    Rgs
  • 01-05-2008 1:48 PM In reply to
    Hi there, ive Googed the Samsung one uve said n got nothing?????
    any thoughts pls
  • 01-05-2008 2:37 PM In reply to
    http://www.projectorcentral.com
    there are a few sites above, they will help you with what is important. i.e. calculating image size versus throw distance and angles etc.
     I diteched Tv and switched to projector entirely and am quite happy with the setup. No B&O though besides sound through BL3/BL2 and BS9000.
    Cheers
    JK
