Latest post 01-04-2008 5:30 AM by Ken. 4 replies.
Page 1 of 1 (5 items)
  • 01-03-2008 9:11 AM
    • Ken
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 60
    DVB-C tuner for BV7-40
    Anyone knows if there is a DVB-C tuner card avalliable for installation in a BV7-40?
    Regards,
    Ken
  • 01-03-2008 9:35 AM In reply to
    Re: DVB-C tuner for BV7-40
    Ken,
    Sorry to tell you that the answer is NO.
    Regards Keith....
  • 01-03-2008 10:42 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    Hi Keith,
    Are you aware if a DVB-C module is in the plans for the near future.
    Ken
  • 01-03-2008 12:07 PM In reply to
    Ken,
    Whilst I have no formal inside knowledge, I would say the chances of B&O ever producing a DVB-C card are zero for many reasons. Connection will have to be via STB controller.
    1. It has always been its stated policy, it will support DVB-S & DVB-T, but will not support cable.
    2. There are so many different frequencies used by cable company which do not conform to standards.
    3. The chances of a positive return on their considerable design development costs are very small.
    I notice from your IP address that you are in Colorado and the large cable industry in the US would be a particular challenge as many of these companies have their boxes made to their spec's
    Regards Keith....
  • 01-04-2008 5:30 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    Hi Keith,
    Thanks for the info. Are you aware of a good external DVB-C tuner that are supported by the STB list in BV7-40?
    In fact I'm based in Denmark, but the gateway I'm using are probably someware in the US.
    Ken
