Thanks very much but my german is not as good as my dutch , portuguese or english ;-)
They seems to talk about the beolab version right ? the pisture is the one from the base amp?
For the BASS drivers and others they are all ordered directly from b&o in b&O Luxembourg shop who the ownwer is Mr OLUFSEN grandson himself - check on the web
one of the BASS DRIVER WAS damaged in the center like it was punched ...
Mr Olufsen recommanded if i replace one to replace them all as the sound will be much different with latest new drivers from B&O - I guess they will be from the MK3 Latest series produced
The MID drivers cant be repaired according to b&O engeneers and replacing them is the best option - the tweeter is my mistake because they advised not to replace them - it is not too expensive though
Bass drivers are 28 euros each , Mid are 33 euros each and tweeter the same - i have sold my ugly triangle that costed much more so even with the refurbishing i save money ;-) - it will make it 1200 euros fully refurbished like new which is cheap for a top of the range designer speaker like B&O - look really matter for me
Thanks very much for your advise on the crossover can you tell me how to improve it , what is the benefit and how to reach the crossover , shall i open the base of the speakers
I am using the latest Onkyo 875 e to drive them they are roughly 140 watts per channel - do you think thet they will sound better if i buy the ICEpower amp that you can buy online like the ASP1000 OR 500 and it will sound much better ?
i will resell the undammaged BASS and Mid drivers on ebay cheaper for those who need them so i can get some cash back
I look forward to reading your comments
Cheers
