Latest post 01-06-2008 10:14 AM by Eugenio Colazzo. 2 replies.
Page 1 of 1 (3 items)
  • 01-03-2008 5:25 AM
    Beovox C75
    Hello
    I need to fix the foam for a Beovox C75 speakers. Just a question, the upper drive has a foam suspension and the lower a rubber suspension; is this right? The two driver (in the same speaker) are different and I don't know if this is correct or not, the code for the woofers are:
    8480143 (B&O)
    8480141 (?)
    The dome tweeter code is
    H216 51/80-3
    I need to change the foam but 2 are in foam and the others are in rubber.
    Where I can find the exact replacements?
    Thanks a lot from Italy
    Eugenio Colazzo
  • 01-04-2008 6:09 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beovox C75
    NoBit:
    When I got some off Ebay a few years back they were exactly as you described. One foam surround Driver and another with a rubber surround. My thought was that someone had fitted CX50/100 Drivers at some stage.
    CraigSmile
  • 01-06-2008 10:14 AM In reply to
    Re: Beovox C75
    There were on ebay.it a few time ago, now this is the thirth couple and this could confirm the technical execution
    thank you
    ciao ciao Smile
    Eugenio Colazzo
