Latest post 01-05-2008 8:08 AM by bayerische. 2 replies.
Page 1 of 1 (3 items)
  • 01-01-2008 6:18 PM
    Beolink 7000 Communication problems
    Hi guys,
    My Beolink 7000 remote has developed itself a problem, while being unused for a year.
    I've kept it in it's loading station, for the internal memory batterys sake, the large battery is now pretty much shot, (again), but it keeps going for regular use for atleast 30min before it fades.
    Now the problem is that it's not communicatiog two-ways anymore!
    I used to remember that above the dot-matrix display at the top there are two infrared diods that actually blinked with a red color just visible to the human eye, but now if a control is sent, or the Beolink 7000 is turned on only the right one does this. The left one seems dead.
    I'm using it with a two-way Beocenter 2300. The Beocenter works, because I tested it with my Beolink 5000, and this one worked perfectly.
    Again, I've tried to do the setup again, and input RADIO and CD and this all works fine, but after this if I choose CD it says, "No Connection" and goes into one-way mode...
    Frustrated!
    Any tips on what to do?
    Andreas
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-02-2008 2:59 AM In reply to
    Re: Beolink 7000 Communication problems
  • 01-05-2008 8:08 AM In reply to
    Die_Bogener:
    If I only spoke German....
    -Andreas
