Latest post 01-01-2008 4:02 PM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 01-01-2008 11:26 AM
    • banger2004
    • Not Ranked
    • Joined on 09-13-2007
    • Clanfield Hampshire
    • Posts 14
    Beo 5 configuration software and Windows Vista
    Hi, has anyone had any experience running the configuration software under Windows Vista?
    Mine works a treat on XP, but a proposed new laptop will be running Vista!
  • 01-01-2008 1:10 PM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Re: Beo 5 configuration software and Windows Vista
    Works just fine! (and not in XP!)
  • 01-01-2008 3:44 PM In reply to
    • banger2004
    • Not Ranked
    • Posts 14
    Hi Doc!
    Many thanks!
    How strange that it works fine on my XP! I think there are issues with certian USB chipsets and drivers?
    Paul
  • 01-01-2008 4:02 PM In reply to
    If your PC uses SIS chip set for USB then you will have a problem.
    Regards Keith....
