Latest post 01-02-2008 9:32 AM by pgtp. 4 replies.
Page 1 of 1 (5 items)
  • 12-31-2007 9:43 AM
    Beolink 1000 remote problems with DVD1
    Hi
     Happy New Year to you.
    I have had problem occur when I fitted my BT Vision to my MX TV about three weeks ago. Strangely my Beolink doesn't operate my DVD1 player any longer. And annoying I have to get up and press play to watch a movie!.
    I wonder if I have changed the settings inside teh DVD player as I tried to configure the BT vision remote to work with teh TV ( I should have known better as it doesn't ) Is there a reset sequence to put the DVD player back to orginal status? Or have a done worse?
    Anyway if anyone can shed some light and get me out of this mess I would be grateful
    The TV works fine and the beolink works as well with the TV, the DVD plays and stops but just won't or refuse to see the remote control. I have tried two remotes!
    Help
    Chris
  • 12-31-2007 10:07 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beolink 1000 remote problems with DVD1
    Firstly welcome to Beoworld. Have you checked the Scart lead for the DVD1 has not come loose. As the I.R. commands are recieved by the TV and then sent along the Scart lead to the DVD1.
    CraigSmile
  • 01-02-2008 8:11 AM In reply to
    • pgtp
    • Not Ranked
    • Joined on 01-02-2008
    • Posts 2
    Hello
    I'm new in Beoworl and I hope somebody could help me.
    I have just bought a BeoVision MX 5500 tv, but I don't know how could it be rotated by the Beolink 1000 controller!
    The motor works fine,  the tv moves into middle position every swith off .
    Help
    Peter from Hungary
  • 01-02-2008 9:06 AM In reply to
    pgtp:
    Hello
    Help
    Peter from Hungary
    Not so difficult. If its the right stand for the MX and plugged in the back just push the picture button. Thern use the >> and  << for turning the stand. Use the Store button 2-3 times to store your settings when you got the ideal angle.
    When you push the picture button the stand is marked at the top of the screen for use.
  • 01-02-2008 9:32 AM In reply to
    • pgtp
    • Not Ranked
    • Posts 2
    Thx a lot, it works!
