Latest post 12-31-2007 11:14 AM by stefan. 5 replies.
Page 1 of 1 (6 items)
  • 12-31-2007 8:00 AM
    need help: AUDIO1 and AUDIO2
    hi,
    I’m trying to configure one of my Beo4 remote to control  a BS9000( as Audio2) and the other BEO4 to control a BC2 ( as  Audio1) but I cannot do it.  I followed the instructions on the Beo4 manual but it’s not working. Even if I have the message STORED on BEO4 display, the AUDIO1 remains as default, so no chance to have access only at my BS9000 ( needs to be set as AUDIO2) as is stated on the manual( I have a BC2 and a BS9000 in the same room). Any chance eventually to control both with one remote in the same room??
    Anyone have suggestions???
    Good luck and happy new year
    Constantine
    all sold!
  • 12-31-2007 8:44 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: need help: AUDIO1 and AUDIO2
    Hi Constatine,
    get your BC2 to Option 1, BS 9000 to Option 4. Now you can control your BC2 by audio commands, BS 9000 by Link-audio commands (Link-Radio, Link-CD...) with both remotes. Maybe you have to add the LINK - button to the list-functions.
    Happy new year
    Stefan
  • 12-31-2007 9:16 AM In reply to
    thanks Stefan,
    I don't have Option4 available on my BS9000 manual( manufactured january 2005) and the RED LED does not blink the moment you set up  Option 4!
    I tried Option 6 but it's not working!
    Any ideea why?
    regards,
    constantine
    all sold!
  • 12-31-2007 9:54 AM In reply to
    • stefan
    • Posts 1,733
    No idea why! Your BS 9000 from 2005 must be a MK III (newest version). Should know option 4....
    Option 6 is a slave-option used for link-rooms.
    So try BC2 in option 4 and BS 9000 option 1. BTW you must be careful because both systems are in the same room that only 1 System receives the option-code.
    Good Luck
    Stefan
  • 12-31-2007 10:32 AM In reply to
    Stefan,
    job done......BS9000 in OPTION0, BC2 in OPTION6 : both connected by MasterLink Cable!
    thanks for your help,
    regards,
    constantine
    all sold!
  • 12-31-2007 11:14 AM In reply to
    • stefan
    • Posts 1,733
    Congratulation,
    yes, it should work with option 0 and 6 if the systems are ML connected. I did not think about that....
    Regards
    Stefan
