Latest post 01-01-2008 2:53 PM by beolife. 4 replies.
Page 1 of 1 (5 items)
  • 12-30-2007 7:04 PM
    Controlling a Beomaster 7000 in a cabinet
     Looking for any info about controlling a BM7000 in a cabinet but not using a extra speaker kit as I am already using one of these for the kitchen, I just want to put the BM7000 in a cabinet
    Had posted tn general forum
    http://forum.beoworld.org/forums/thread/74244.aspx
  • 12-31-2007 6:25 AM In reply to
    Re: Controlling a Beomaster 7000 in a cabinet
    There was a mod kit from B&O to do this,but it involved dismantling the equipment and running a cable out the back of the Beomaster to a special receiver.
    Are you using a two way remote device,such as BL7000,or the simpler BL1000/Beo4?
    The simplest method,is of course to use another Link kit,it's no problem that you have one on the system already.
    There is another option,that works perfectly well,but is a bit "Heath Robinson".
    Regards,
    Nick
  • 12-31-2007 1:42 PM In reply to
    Hi Nick
    do you have any more info  regarding running a cable to the Bm7000 as I could then use one of the newer round IR sensors which I know work with the BM7000 as this would then enable me to have the control I want.
    I do have a BL7000 but do not really use it mainly a Beo4, I may yet sell the BL7000 to fund a Beo5.
    Tell me more about the "Heath Robinson" option.
    Just to add I have 2 BM7000's one which is used for the kitchen & patio in conjunction with the link kit for the patio & the other one will be used for the bedroom but will put in the same cabinet as all of the other equipment, so as you can see I need to control them independently.
    Simon
  • 01-01-2008 7:10 AM In reply to
    Simon,I did'nt know you could use the later (ML,round) sensor with the BM7000? I've got one somewhere,I'll try it.
    I may have a part No for the original kit,and more info.
    I've also sent you a pm.
    Nick
  • 01-01-2008 2:53 PM In reply to
    Hi Nick,
    did you have any luck with the IR sensor,
    Could you let us know how you wire up the "Heath Robinson"
    Regards Simon
