Peter is correct ( again !!)
The STB he refers to is a control system that allows the B&O product to control your digibox. standard on later MX's, most Avant variants, and all panel TV's.
If your considering a new Bcen 6, then I suggest you contact your local dealer - put these questions to him/her, and you should be sorted - wether you get a new TV or modify your exisiting one. - BTW - not all MX TV's can control digiboxes, although all are compatible ( despite the digital switch over scaremongers) - you would just end up using the SKY supplied remote if your MX is older.
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
