Hello all;
I am having a bit of trouble setting up my AV2 options. My TV, Beovision MX 7000 is currently linked to a B&O video player on AV1 and a SAT decoder on AV2. When I press the menu button on the remote (BeoLink 1000) two options appear on the screen, Channel List and Setup. In the setup the two AV ports are set to B&O Video and AV2 to decoder. The main problem is setting one of the channels to receive the decoder only. When I press the "Go To" button on the remote, a strip shows up on the top of the screen and displays three main options: Tune, decoder off, and System. I can tune the channels, and figured out a way to change the System (not really knowing what that does) by pressing "Shift + 3". The problem lies in changing the "decoder off" setting. I imagine since there is an option for OFF, there must be a way to set it to ON so the channel would receive the dedicated frequency from the decoder. Currently I have to switch my decoder off and on again so the impulse is sent to the TV, thus receiving the decoder signal.
Any help with this issue would be much appreciated. Thank you.
