1st March February 2012
Latest post 03-11-2008 11:22 PM by Rapidroy. 20 replies.
03-07-2008 12:35 PM
Rapidroy
- Joined on 03-07-2008
- Posts 35
what size is the plug of a Beocenter 9000 relay socket?
Hi All I want to add an amp to my 9000 and want it to trigger the amp with the 12v relay socket (part # for the cable is 4002) anybody know the size plug is need? Thanks Roy
Rapidroy
- Posts 35
Re: what size is the plug of a Beocenter 9000 relay socket?
Hi I'm in Albuquerque, NM. My big plan is to add a AudioSource AMP300 and preamp it with the Beocenter 9000 to power my Acoustat Model 4's. Right now I'm using my Sansui G-6700 to power the Acoustat's but it really does not like the 2ohm load. I put a call to a B&O place it California and he said he'll look to see if the kit was still around. But if you find yours I'm sure we can make a deal.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Rapidroy: Hi I'm in Albuquerque, NM. My big plan is to add a AudioSource AMP300 and preamp it with the Beocenter 9000 to power my Acoustat Model 4's. Right now I'm using my Sansui G-6700 to power the Acoustat's but it really does not like the 2ohm load. I put a call to a B&O place it California and he said he'll look to see if the kit was still around. But if you find yours I'm sure we can make a deal.
I thought you might be "across the pond". In which case I believe you will need the 120 volt version which I think was a type 4001 remote mains switch.
Ben
- Joined on 12-28-2007
- Taunton, UK
- Posts 131
I might be interested in this kit if it works with a Beomaster 5000. Please let me know. Cheers, Ben.
Frank Rizzo
- Joined on 05-15-2007
- Posts 599
Hi Graham and others.....i'm curious....how does this 4002 or 4001 kit work??? What's the basic principle?? Thanks !!
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Ben, I believe the only two products it would work with were the Beocenter 9000 and the Beomaster 5000. For using it with other products you needed a special lead which conected to the Powerlink sockets. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Ben
- Taunton, UK
- Posts 131
If this kit is no good for Roy, i'd be interested if its still available. I'm using external power amps on my Beomaster 5000, and was thinking this would save me having to power them up and down seperately. Thanks, Ben
joeyboygolf
- Posts 3,252
Frank Rizzo:Hi Graham and others.....i'm curious....how does this 4002 or 4001 kit work??? What's the basic principle?? Thanks !!
It's a 12 volt relay which when powered from a socket on the Beocenter 9000 can be used to power on external devices such as power amps. I used it when I had the Quad 405 with my BC9000. It has a timer facility as well although I never quite got the hang of that.
joeyboygolf
- Posts 3,252
ben12345: If this kit is no good for Roy, i'd be interested if its still available. I'm using external power amps on my Beomaster 5000, and was thinking this would save me having to power them up and down seperately. Thanks, Ben
As there is no dedicated socket for this device on the BC5000 you will need to arrange a 12v supply from the Beocenter which will trigger the device when the Beocenter play function is activated. It could be done and there is a socket included with the kit for just this eventuality.
Craig
- Posts 4,855
Acording to the user manual the Beomaster 5000 does have a dedicated connection for the relay. Craig
joeyboygolf
- Posts 3,252
Craig: Acording to the user manual the Beomaster 5000 does have a dedicated connection for the relay. Craig
I should have checked, thanks Craig. So the 4002 should work out of the box! Send me a PM Ben, if you are interested in it.
PL212
- Joined on 02-14-2007
- Moderator - Seattle
- Posts 318
joeyboygolf: It has a timer facility as well although I never quite got the hang of that.
I have the North American version of this and, as near as I can tell, the "TIMER" indicator on the front is just to let you toggle between having the outlet controlled by the BeoCenter and having it powered all the time. As others have noted, you can use this with modern, PowerLink equipment by use of a simple breakout cable that B&O has. However -- and I'm not sure if this is important in GB -- the outlet on the back is non-polarized, at least on the 110v version. It's hard finding equipment that will plug into a non-polarized outlet nowadays.
Frank Rizzo
- Posts 599
Very cool....thanks Graham !!!!!!
Frank Rizzo
- Posts 599
Hey Roy...you're not too far from me ...i'm in Colorado..
Rapidroy
- Posts 35
Hi Frank Are you in Denver? I got some parts from a place in Denver that services B&O but I can't remember the name or phone # would you have that info? and to anyone that knows, does the 4001 or 4002 (i found a photo of it on this web site) just triggers 1 ac outlet ie. you plug the 12v wire to the 9000 and then you plug the 4001 to ac then you plug 1 thing like a amp or lamp to it? and then when the beocenter is turned on it sends 12v to a relay in the 4001 which sends power to the ac outlet.
Frank Rizzo
- Posts 599
Hey Roy....yep its the Gramophone Shop (303) 744-1284.. Send us a link so we can see the pic of this thing>....Thanks...
joeyboygolf
- Posts 3,252
Rapidroy: and to anyone that knows, does the 4001 or 4002 (i found a photo of it on this web site) just triggers 1 ac outlet ie. you plug the 12v wire to the 9000 and then you plug the 4001 to ac then you plug 1 thing like a amp or lamp to it? and then when the beocenter is turned on it sends 12v to a relay in the 4001 which sends power to the ac outlet.
That's correct Roy.
Page 1 of 1 (21 items)
