        1st March February 2012
	    Latest post 02-16-2008 9:50 PM by  darioazul. 11 replies.
								        02-09-2008 4:21 AM
									        jooka
								                - Joined on 04-15-2007
								                - Posts 185
										    how capable beovision 7 with beolab 7-1 is as source for music and video?
										    how capable beovision 7 with beolab 7-1 is as only source for music and video? i mean are there anyone here who feels it can deliver superb sound for cd listening without extra speakers and subwoofer's attached. for example, is sound similar what beovision 6-26 delivers? bit tired of cable mess on the floors where system usually is standing. any thoughts of this subject are welcome!
									        Ehlerz
								                - Joined on 04-17-2007
								                - DK
								                - Posts 510
										    Re: how capable beovision 7 with beolab 7-1 is as source for music and video?
										    The Beolab 7-1 or 7-2 are very much capable of delivering great sound. Actually you will not believe it the first time you experience it. I had the Bl 7-1 and was very satisfied until i bought a surroundsetup.I then switched it to 7-4. The sound of 7-1 is wayyyyy better then that of other beovisions. Ofcause its overall use depends on your livingroom size etc.  You should visit a B&O dealer, they will be more than happy to give you a demonstartion.
									    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
									        Niveau
								                - Joined on 09-25-2007
								                - Posts 63
										    Ehlertz,  I also bought the BL9 for surround with 7-40. Considering shifting my rearspeakers into BL3... Seems from your setup that you also are having this setup... How do you like the BL3 in this setup? The Dane
									    Maybe this is as good as it gets...
BV7-40 MKII, BL9, BC2, BL6000, MX4000, Beosound 3, HDR1
									        Ehlerz
								                - DK
								                - Posts 510
										      Niveau:Ehlertz,  I also bought the BL9 for surround with 7-40. Considering shifting my rearspeakers into BL3... Seems from your setup that you also are having this setup... How do you like the BL3 in this setup? The Dane
 Hello Dane Yes i have the Lab 3´s as rear speakers and the combination with Bl 9's as front in my opinion is almost as good as it gets. I use them on floorstands and they are very nice, watching movies aswell as listening to music in speaker 4 mode. As your frontspeakers have acoustic lences so should your rearspeakers IMO.
										    7-1 is a very capable speaker and is actually better than some of the stand alone speakers.
  Of course you wont get the sound stage and imaging that you'll get from stand alone speakers (assuming the set up is correct) but the quality of the sound is excellent if perhaps a little forward in the mids. This is to be expected however as it is a TV speaker and is set up to produce dialogue. I don't think you'd be dissapointed providing you accept the short comings mentioned above. jazz
									        Emmanuel92
								                - Joined on 02-14-2007
								                - Paris
								                - Posts 2,032
										      Ehlerz:The Beolab 7-1 or 7-2 are very much capable of delivering great sound. Actually you will not believe it the first time you experience it. (...) The sound of 7-1 is wayyyyy better then that of other beovisions.
 Totally agree, I did not believe it too the first time I heard it, and I am still amazed by this wonderful loudspeaker.
									    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
									        Alex
								                - Joined on 04-16-2007
								                - Bath & Cardiff, UK
								                - Posts 2,990
										    The BeoLab 7-1 and 7-2 are stunningly good. I'm still surprised every time I hear one just how they defy the sound you'd expect. I'd compare them to BeoLab 3s in a lot of ways, definitely a massive step up from the BeoCenter 6 you mention... completely different sound...
									     Weekly top artists:
									        jooka
								                - Posts 185
										    what do you think of using it as a only speaker for cd music? does beovision 7 play all the music cd's and is it easy to use as a cd-player?
									        Alex
								                - Posts 2,990
										    Yes, it will play any normal CD I've come across, and also plays some fancy formats such as MP3 disks etc...
And yes, it's great as a speaker solely for CD music, I'd be happy with it. However if can get BeoLab 3s instead, I would suggest it as you'll be able to place them wider apart...
									     Weekly top artists:
									        jooka
								                - Posts 185
										    thanks, alex. what about screen specs on beovision. are all models from day one hd ready?
									        darioazul
								                - Joined on 04-30-2007
								                - USA
								                - Posts 249
										    Dear Dane:   I would also support the idea of getting BL 3 as rears with BL 9 as front.  The BL 7-4 makes a compelling center channel.   Enjoy,   Dario
									    When I hear music, I fear no danger.
I see no foe...
Thoreau
        Page 1 of 1 (12 items)
