Latest post 02-01-2008 11:26 PM by Chrisreunion. 2 replies.
Page 1 of 1 (3 items)
  • 02-01-2008 6:23 AM
    BEOLINK PC2
    I have a PC2/beoport connected to my PC, the beopc2 has no IR eye or speakers connected, it is however ML to a Beosound 4 that has Lab 6000 connected, they are both in the same room.
     my question is what option should both be set to and should the speakers be connected to the BS4 or the Beoport
    Jon
  • 02-01-2008 8:04 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: BEOLINK PC2
    Speakers shall be connected to the BeoSound 4. The BeoSound 4 shall be set to option 1, and the BLPC2 shall normally be set to Option 6 if placed in a separate room - or 4 if in the same room (4 = only reponds to Beo4 IR-signals if the Beo4 display reads LINK) - but this is obviously less important as you no IR-eye connected to the BLPC2.
    Roger
  • 02-01-2008 11:26 PM In reply to
    Re: BEOLINK PC2
    Sorry, but I think BeoPort should be set to option 0 (because no IR eye is connected to it), so all controls will come from BeoSound 4.
    Indeed all speaker connections should be made on BS4 , if you decide to use BeoPort in another room, then you can always buy a longer Masterlink cable and have a second room with B&O sound through your BeoPort!
    Reunion Island is greeting you!
