Latest post 01-17-2008 4:37 PM by Coolskin. 3 replies.
Page 1 of 1 (4 items)
  • 01-13-2008 11:23 AM
    BV7 - Digital Audio input
    I recently bought a Mac mini. I wanted to get Digital audio out into my BV-7. I have bought a M-Audio Transit USB device which connects to my Mac mini giving a AC-3 output. When i connect this to my BV-7 it does not work i have standard stereo conected to AV-4 and selected the A2 input for digital audio. A1 is used by sky HD.
    Any help would be appreciated, thanks
  • 01-13-2008 1:22 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BV7 - Digital Audio input
    The BeoVision 7 cannot handle a standard stereo input, but will only take Dolby Digital or similar via the digital connections.
    You say you've connected a 'standard stereo' connection to AV4, I assume you mean you also have sound going between the Mac and the BeoVision via plain stereo analogue?
     Weekly top artists:
  • 01-17-2008 11:40 AM In reply to
    Yes i am getting stereo ok. But the digital sound AC3 output from the Apple Mac connected to A2 is not functioning.
  • 01-17-2008 4:37 PM In reply to
    (Reference post)
    Filed under:
