Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I recently inherited a Beo trio BM8000, Beocord 8002, and
Bgram 8000, along with a pair of M100’s. They’ve been sitting, unused for the better
part of 12 years at least. I was told
that nothing worked, and that the outputs were blown (it almost went to the
land fill!). I couldn’t let it go anyway.
Upon further inspection, (the first thing out of the trailer and into
the house) I was pleased to get lights on the gram and master. First I checked the headphone output, and
thought/imagined I heard a faint sound. Lo
and behold, when I connected the 100’s, she came to life! There are (surprise, surprise) still
issues. They amount to these so far:
1) The master does shut off after
about 15 minutes of moderate use (cap problem?)
2) The
Bgram plays, but the tone-arm gets stuck and the transport is not smooth.
3) The Beocord does not power up at
all. I checked the transformer, which
does not even warm up, and the fuse appears to be OK, but the contacts to the
main ribbon cable are pitted/corroded.
I am of course interested in
getting the system fully functional, with a Terminal and CD if I can find one. I have read several posts about cap kits and
such and would like to know how to obtain them. Also Mohawk, if you’re out there I would be
interested if you’d be willing to either share your PCB drawings for the boards
you had made or the supplier that manufactured them.
Thanks for a great site.
BeoMaster 8000, Beogram 8000, Beocord 8002, Beogram CD50, M100's.
Beocenter 9500 Beovox P45's
