Latest post 01-02-2008 6:31 PM by GeoffM. 5 replies.
Page 1 of 1 (6 items)
  • 12-26-2007 5:16 PM
    • GeoffM
    • Not Ranked
    • Joined on 12-26-2007
    • Posts 3
    Beomaster 1900 no longer working
    Hello,
    My beloved B&O1900 has stopped working after many years of sterling service, can any one help please?
    From standby when I press any of the touch buttons now a loud buzz emiits from the speakers and it cuts off as soon as the touch control is released. No music can be heard. It did get a bit warm in recent weeks, the centre of the bottom plate seems warmer than usual, but no smoke!
    I am guessing it might be a mains supply problem??  Has any body else ever experienced anything similar with this or more recent models? e.g 2000, 2400.
    I have recently moved to Shropshire, from another area can anyone recommend a good service agent near here?
    Many thanks
    Geoff
  • 12-27-2007 7:11 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1900 no longer working
    Geoff,
    Welcome to Beoworld !  Yes -  thumbs up
    Try without speakers connected and let us know what happens.
  • 12-27-2007 1:48 PM In reply to
    Geoff
    I have no personal experience to draw on but I have heard a lot of good things about the B&O dealer in Chester and I know they are happy to deal with older B&O products.
    Simon
  • 12-31-2007 3:01 PM In reply to
    • GeoffM
    • Not Ranked
    • Posts 3
    Hello Dillen,
    Thanks for the prompt reply. I moved three months ago and had not attempted to use the 1900 since due to the problem. But I got it out again yesterday, and to my amazement it worked fine!! However after about hal am hour a loud "crack" comes through the speakers like an electrical discharge. IIts still working at the moemnt but every few minutes it makes this noise. So its more like a component breaking down, possible in the output stage?? What do you think?
    I guess I will have to wait for it to stop working altogether and then take it into a shop. possibly in Chester, thanks for the tip Simon.
    Regards Geoff
  • 01-01-2008 11:07 AM In reply to
    • Dillen
    • Posts 5,008
    Most likely a case of aging capacitors.
    Grab a capacitor kit and send in for service with the Beomaster.
    Maritn
  • 01-02-2008 6:31 PM In reply to
    • GeoffM
    • Not Ranked
    • Posts 3
    Hi Martin,
    I spoke too soon, its stopped working now, just a sharp buzz if any staion button, or tape /phone is selected, which on release stops the buzz but returns to standby mode.
    If you still think its capacitors, where , how can I "grab a kit"?
    Regards Geoff
