Hi, ()
I have a digital receiver from SAGEM (and it's on the STB list of my B7) in combination with an infrared unit making it possible to communicate with my new B5 (by use of the Control IR Out port). Initial problems encountered ..
1) When choosing 'MENU', on B5, I get like the root (setup-)menu of the SAGEM receiver (full screen view). When I use B4 (and press MENU) I get like a grey left-handed area covering 1/4 of the screen - from here I have like 5-6 options covering most useful features on the SAGEM - If I choose MENU from these options I'm routed to the point where B5 ends up in the first place. Shouldn't the MENU choice for B4 and B5 be the same? (I like B4's menu for choice).
2) When using B5 I can't use the arrows (step up/down) in programs but have to go to the digitals pressing the numbers every time I want to shift channel - solution: new firmware?/or is it easy to correct for the dealer? (You may ask - why don't you use the TV logos when changing channel? - not set up for my digital receiving part...yet)[:'(] I think I've heard abt similar problems for B4 & SAGEM receivers in the past?!
[In Denmark SAGEM'60 is like std choice for many users as biggest cable provider TDC offers this product at reasonable cost - where did you say B&O originated from? crowds will come to Struer if not settled soon
/L
