Quick bit of back ground here before diving into the question.
The panasonic Digi-box my Grandads been running on his BV7 (I think MK1? Purchased 04/06) has given up and died. This being the second one I called sean at the Mailbox to see if there were better alternatives. Sean advised me to look at Humax or the B&O DTV (thank you Sean for your help).
I whizzed down to Comet and £180 later picked up a Humax PVR9200TB, Took it back to my Grandads hooked it up including the IR cable and installed it as each of the Humax boxes on the control list but I still can't control it using the Beo4.
Does anyone know if a software update on the BV7 will give me the Humax PVR9200TB as an option on the control list and also what the cost of the update will be?
