Latest post 12-22-2007 8:06 AM by meandmyshadow. 1 replies.
Page 1 of 1 (2 items)
  • 12-22-2007 7:10 AM
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    Serene/BC6000 Sync Question
    Hello,
    I have just bought a Serene and have sync it with my PSTN (MkII) & 2 x BC6000. I initally had a bit of trouble with the numbers (adding 44, and 0's all over the place but I think I've figured that out now). Anyway..........When I add a number via the Serene I can set it as a common or private number, a common number is copied to the PSTN base and thus appears on the BC6000, whereas a private one only appears on the Serene, but you can't seem to do it the other way around - i.e. make a number private on the BC6000 - Some numbers I only want on the BC6000 and not sync-ed the Serene. Can this be done?
    Thanks.
    Ian
  • 12-22-2007 8:06 AM In reply to
    Re: Serene/BC6000 Sync Question
    The simple answer is no, you can set the handset to be 'common' or 'personal' but not an individual number.
