1st March February 2012
Latest post 12-17-2007 6:45 PM by ipaul. 9 replies.
12-17-2007 9:38 AM
Graham1982
- Joined on 11-22-2007
- Cambridge, England
- Posts 531
Picture in Picture module
Hi: I have a basic understanding of electronics and have built and stripped down PCs in the past. Thus if I bought a PinP module for my Avant would it be like installing say a PCI card or ram upgrade in a PC. Also I have heard I would need a special screwdriver - is this B&O specific or could I get it from a hardware store? Thanks Graham
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: Picture in Picture module
Graham, if it is like the one for the MX5000 then it is just plug and play. Not sure about a special Screwdriver. Would imagine it just a Torx type so easily available. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Graham1982
- Posts 531
Hi: Thanks what is a Torx screwdriver - star drive/philips? Thanks Graham
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
d) is torx ( c) is phillips) Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Graham1982
- Posts 531
Hi: Thanks, you learn something new every day - I also like messing around with old Jags and I often use star drive sockets which is what that is. I probably invented that term but am glad I know the right term now...
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
kallasr: d) is torx ( c) is phillips) Ralf
Incorrect, b) is phillips and c) is posidrive
kallasr
- Posts 1,077
joeyboygolf: kallasr: d) is torx ( c) is phillips) Ralf
Ok, I should have paid better attention to the english wikipedia ... Sorry for the confusion. Ralf
ipaul
- Joined on 04-22-2007
- Posts 378
.....And the installation of the PIP module depends of the type of Avant, but you could do it i think, i did one on the T8111 which is installing the board (yes: with the torx screw, and you'll needs torx (15 i think) to open the Avant). Plug one connector in and cut 4 jumpers on the board behind it, for the later Avants it might be different again...
Page 1 of 1 (10 items)
