Latest post 11-29-2007 9:25 PM by jvezina. 1 replies.
Page 1 of 1 (2 items)
  • 11-29-2007 4:35 PM
    • cbl
    • Not Ranked
    • Joined on 04-18-2007
    • Posts 11
    from bv7 mk 2 to mk3
    just a new happy owner of the mk3 after one year with the mk2
    and the sound and picture are without doubt much better in terms of sharpness,blacklevel and movement.
    sound better dynamics and cleaner.Now the bv7 are nearly worth what yoy are paying .
    only one problem.... i have the samsung hd cable box dcbh360 but cant find it in the stb menu.
    and do anybody use a sony harddisk  recorder and how can it be controlled.
    best regards and thanks for a great forum
    cbl
  • 11-29-2007 9:25 PM In reply to
    Re: from bv7 mk 2 to mk3
    cbl:
    cbl
    I have a Sony DVD recorder with hard disk and it can only be partially controlled .Some options such as TITLE LIST and TV GUIDE are not emulated and you have to use the original remote to select these features. Power on, cursor movement, numbers and selection are provided and the Beo4 can be used for these purposes. The only Sony DVD recorder with hard disk supported is the RDR HX-1010, an European model. But others use similar IR codes.
    Best regards,
    Jean
