Some months ago i recived my Beogram CD 5500 and i then completed my Beosystem 5500. However I did a big error when I tested the CD since i forgot to unplug the transportplugs (not good...) but i seem to recall that it did behave nicely the first couples of days after removing plugs. Then it started to be more and more quick to close the CD-tray, it have even been time when i almost have to struggle in order to aviod getting stuck in the CD-tray. At the time i suspected that it was my big error with the transportplugs that maybe have done something bad but now i start to more and more think that maybe the error was from start. I have read thru the servicemanual and i cant see anything that could have "gone loose" with the CD-tray in order to make this behaviour. As it is right now the tray stays open around 20-30 sec and then closes and even with or without CD it activates the Beomaster wich then turns on and starts to play if there is a CD inside the tray. If none then CD goes to standby with Beomaster still active on CD. The CD-tray doesnt feel strange at all, the function itself seems 100% working, nothing loose or so, just that its very eager to close the CD-tray.
 Does anybody have a good and hopefully easy way to fix this?
Cheers and thanx for all the help.
Jesper L
Sweden
