Latest post 11-28-2007 6:30 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 11-28-2007 10:48 AM
    BC9500
    I pressed shift+radio for the line input. All works fine but now the system will not monitor other sources through the speakers. Pressing Atape for e.g and the tape starts but no sound. shift+radio (line input) is now the only source available. Help please.
    David
  • 11-28-2007 11:07 AM In reply to
    Re: BC9500
    It's got it's knickers in a twist somewhere. Is this a stand alone 9500 we are discussing or part of a link system?
    If stand alone, do the front panel controls work as should. ie not using a remote?
    If not then suggest unplug from mains, leave 2 mins then plug in and try again.
    Regards Graham
  • 11-28-2007 1:20 PM In reply to
    Re: BC9500
    Sounds like you've removed the dummy plug that goes into the "line in/out" socket? If so,put it back,then connect your (i.pod?)to the Aux socket instead.
    The line in/out socket is for connecting an external sound processor,or what one client referred to as a "graphic sympathiser".
    Regards,
    Nick
  • 11-28-2007 5:29 PM In reply to
    Re: BC9500
    Correct as usual Nick,
    That is exactly what I did. Beomaster 6000 has a similar socket "EXT" for the purpose. I will use the TV/AUX or TAPE 2 socket in future. Also correct it was an Ipod!
    Regards
    David
  • 11-28-2007 6:30 PM In reply to
    Re: BC9500
    Good spot Nick!
    Regards Graham
