        1st March February 2012
	    Latest post 10-22-2007 1:17 PM by  eduard. 8 replies.
								        10-06-2007 6:13 AM
									        Craig
								                - Joined on 03-29-2007
								                - Costa Del St Evenage
								                - Posts 4,855
										    BeoPort is all wrong, well the track order is...............
										    Need some help with my Beoport. Everyrting was working fine until I got a new PC. Backed all my music files to an external Hard Drive. Loaded Beoport Software O.K. Now all my albums are in Alphabetical order, not the normal order. They are in the right order when I look in Widows Media Player. Also I get an error message when I try to access N.radio.   Craig
									    For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
									        Jandyt
								                - Joined on 04-01-2007
								                - Clitheroe, Lancashire, UK
								                - Posts 13,004
										    Re: BeoPort is all wrong, well the track order is...............
										    Hi Craig. Hope you are well. Are you looking under 'Folders' instead of 'Albums' by mistake? Just a thought. Andy T.
									        Craig
								                - Posts 4,855
										      jandyt: Hi Craig. Hope you are well. Are you looking under 'Folders' instead of 'Albums' by mistake? Just a thought. Andy T.
   Good question, and the first thing that came into my mind. Unfortunately that is not the case. Infact they are both the same.   Craig
									        Craig
								                - Posts 4,855
										      eduard: Hi Craig,   Do you have a new wireless connection to the internet, and if so.... please check the settings, your comp. is not getting on the internet with beoport...
 No we have a wired network and both PC's can access the internet O.K. Could it be that the new PC is running Vista?   Craig
									        Craig
								                - Posts 4,855
										    Well the only problem I know of with Vista. Is with the 64 bit version. there is a problem with the USB Drivers I believe. Going to try a de-install/ reinstall, and se what happens.    Craig
									        Craig
								                - Posts 4,855
										    Well just to update the situation for anyone who has this problem in the future. What was wrong was that I had not used Windows Media Player. As the two programs work together. It seems that I first needed to set up the Library in Media Player first.   Craig
        Page 1 of 1 (9 items)
