I have just upgraded my BeoPort software, which included an un-install. After this process I had to re-install the Config software. Just a warning.
Greg
Why did you have to uninstall the previous version of Beoport ? It should just update the installed version unless you have a corrupt installed version.
Regards Keith....
Tried to upgrade BeoPort yesterday from 4.50 to 4.65, but it did not work either. So I also had to uninstall the previous version.
Can't comment on the problem with the Beo5 SW, as it is on a different pc.
Marcus
