Many thanks for your suggestions. A service guy was here with the ML tester and there was no cabling failure visible.
Do you think it is necessary to examine all the boxes as the test has had a good result?
I also did desconnect the complete system from power and then repowerd in this order: BV7, BS9000 (then reprogrammed all options), then Beoport, BL2000, AV5 and finally BV1L. The second time I changed order of AV5 and BV1L. Result has been the same: with the last device the BV7 indicates CI failure. The system then works normal but after some time (e.g. the next day) the BS9000 hangs :-(
The service guy had no idea if there are some restrictions in network topology. Have you got any experience with disturbance? Does a DECT base influence the signalling? Or does WLAN? Or a normal LAN cable that is run in parallel even if both are shielded?
I have no idea how to solve the problem?!? There might be the possibility to shorten the cabling of the BV7 and the BS9000, but as this means enormous effort, I would be glad to get a feeling if this could improve the situation.....
Thanks, Marcus
