Nice link but errr... no less than 3 different belts listed for the 5000, one is currently being custom made. Probably because they found out that none of the ones they sold already didn't quite fit, which BTW is correct. ![Laughing](http://forum.beoworld.org/emoticons/58.gif)
- And two different sizes for the Beogram 3000 (type 5231) and for the Beogram 1900 - messed up pretty good.
Did someone actually ever buy from them with success ?
I never used silicone for the damping cylinder in the 400x series. After cleaning with isopropanol (tapehead cleaner), I normally use a tiny amount of acid-free oil (sewing machine oil) smeared inside the brass cylinder using a little finger, it will be adequate for many years. It will also be far easier to clean off again in the future should the need arise.
