1st March February 2012
Latest post 12-16-2010 5:58 PM by BeoMegaMan. 10 replies.
11-06-2010 4:49 PM
BeoMegaMan
- Joined on 11-25-2007
- Posts 66
Paint Your BeoSound 1 Grill?
I have a BS1 in white which has seen better days on the grill. I am wanting to buy a new one, but not convinced it wouldn't be cooler to paint it a unique color of my own. I have seen a few limited editions which dealers have had painted for them by artists, but I would like to do my own. Any idea's on how I should go about it and what paint type of paint to recommend?
BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Re: Paint Your BeoSound 1 Grill?
Hi Spiros,
How do you remove the grill of a Beolab 2000. Can't seem to find a way how to do.
Has it been double taped?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Stoobietoo
- Joined on 03-28-2008
- Exeter UK
- Posts 145
Leslie:
The grills slide upwards to remove them. I placed a credit card between the bottom of the speaker grill and the plastic of the speaker and wiggled it about, you wll see the grills move up a little and you can then keep sliding them up. Don't use anything that is metal or hard that may damage the grill or the plastic.
Stoobie
Leslie
- Netherlands
- Posts 2,201
Thanks Stoobie, will give it a try tomorrow!
BeoMegaMan
- Posts 66
Pics of the final product. I first tried a solid color but you could still see the dents and knicks in the front of the grill. I then decided to do a graffiti theme on it since it will go in my garage. All lacquer black, red, silver, spray finishes with some accents of gloss regular black and white. Finished with clear coat. Sorry for the poor pic as I snapped it with my iphone on the way out while it was drying.
- Joined on 12-05-2007
- Posts 486
That reminds me of Eddie Van Halen's guitar!
BeoMegaMan
- Posts 66
I was going for a industrial graffiti look, but I can see a little Eddie in it as well :)
Michael
- Joined on 05-20-2009
- Glen Waverley, Victoria, Australia
- Posts 245
Looks great. Very individual. Nothing like a paint job to freshen up anything. Well done.
Michael.
BeoMegaMan
- Posts 66
Thank you kind sir, def. freshens the place up.
Page 1 of 1 (11 items)
