Basically I have a Beolink Passive that I am using for outdoor speakers. I have a pair in the front and and pair in the back, basically I put a switch in to switch between the two pairs.
The beolink eye is in a weather proof box mounted under the eaves of the roof in the front yard. I only have the IR wired, I am not using the buttons in front because it is mount high under the eaves and can't reach it. OK, so I have read that I can tie two IR Beo eye pucks in sequence, but since I am only using the IR I just need a IR detector. Does anyone have a schematics on how I wire a 455khz infrared red detector to a beolink passive? i.e I want to make a down and dirty beolink eye without the need for the buttons, it just needs to send the ir to the passive.
Eric
