Latest post 10-21-2007 8:30 AM by BenSA. 4 replies.
Page 1 of 1 (5 items)
  • 10-20-2007 6:14 PM
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Screen resolution resets itself!! Help!!
    Having a problem with my laptop! I set the screen resolution to 1023 x 768 (Which is recommended by the manufacturer as well)
    Problem is 99% of the time the computer will almost be finished booting (correct screen resolution will be showing) when it will reset itself to to the lowest resolution! I have tried everything! Once or twice it'll load fine but the majority of the time it resets! Of course all my desktop icons go all over the place.
     I hope someone has an idea for me
     P.s. I've checked that the driver is properly loaded.
    Durban South Africa
  • 10-20-2007 9:18 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Screen resolution resets itself!! Help!!
    Hi B !
    Do you have another display connected as well ?
    Or is the graphics-card perhaps set to multiple displays ?
    (reason i ask is that on my previous laptop the same thing happened)
  • 10-21-2007 2:21 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Hi Ignace
     Yes it is set to multiple displays! There are 3 actually. I don't need the multiple displays, I only use the laptop screen. Is it possible to change that setting to one display only. I'm using windows XP Pro
     Thanks for your reply, it makes perfect sense.
     Regards
    B
    Durban South Africa
  • 10-21-2007 4:55 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Hi B,
    Yes, it should be possible to change the setting to 1 display only.
    Do you know what brand / type of graphics-card you have ?
    See if you can locate the configuration-software in the Control Panel,
    there is the standard Windows "Display"-pane where you can select the display-settings,
    but frequently there also is a settings-pane from the graphics-card itself,
    like f.e. "NVIDEA Control Panel" or similar.
    Usually, you can select/deselect multiple displays there.
    Regards,
    Ignace
    P.S.
    How is the new job ?
    Smile
  • 10-21-2007 8:30 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Hi Ignace
     I will give that a try. Its an Intel(R) extreme graphics driver. Sure I'll be able to sort it out
     Thanks so much
    B
    P.s. The new job is going really well. Enjoying it a lot
    Durban South Africa
