I have a Beosound 4 and use the A.Mem function quite often to listen to my music on the SD card.
Now the last few days i am having following problem:
I do have different folders on the card, these contain 10-15 songs each. BS4 displays the names of the folders, everythig alright. But sometimes, it just stops playing after a song is over. So when i rotate the right control pad to jump to the next song, in the display i see how BS4 counts up. So for example last song in a folder was song number 10, then it stops after number 10 is played, but when i rotate the pad, then it counts up to 15 or so (but there are actually not more than 10 songs), after it realizes there are no more songs, it jumps to the next folder as it should and starts playing the first song of that folder. Now i do not know why BS4 just stops after the song sometimes. It's not always the same song, i already checked this.
My songs on the card are partially directly copied from my mac onto the card, the others where copied from a CD using BS4. I also have "repeat" activated.
So i don't know what i am doing wrong. It's just a little boring that after a few songs i find out that no more music is playing and i have to skip forward manually in order to have the music continuing.
