I have just got myself a second hand beocom 6000 MK1 with the pyramid base station.
When I got a new battery the phone powered up perfectly and worked fine. I tested it to make and receive calls. However it was full of the previous owners information and phone numbers.
I decided to reset to factory specs. However i think I made a big mistake:
I used the code DOT 70009 to reset the handset and this worked fine. All the phone numbers were gone. I now realise I should have done the DOT 70008 number and reset the base.
Now the handset cannot communicate with the base.
When I power up the handset says "Not Registered"
If I turn the wheel it says "no signal"
and "phone book ***UPDATING***"
and "not base 1"
If I try and reset the base using the code it says "base connection ***ERRO***"
if I place it on the base it says "search base wait" for quite while and then says "Not Registered"
I tried turning of the base and the handset overnight- no luck
it seems there is no way to make the base visible to the handset. Do I need to take it in for repair?
any help much appreciated.
