Latest post 01-29-2012 1:32 PM by akoro. 3 replies.
Page 1 of 1 (4 items)
  • 01-29-2012 7:00 AM
    • c1010
    • Not Ranked
    • Joined on 04-18-2007
    • Posts 14
    Beocenter 2 - No CD sound. But radio and DVD OK
    Setup: Beocenter 2 MK I on Beovision 7 MK IV with Beolink 1000 remote (previously Beo 5)
    When starting the cd there is no sound. If I shift to DVD on the remote there will be sound from the CD. But also TV-position and the screen is "alive" with a slight light.
    When starting a dvd there is sound and picture. As expected
    When starting radio there is sound. As expected
    This is both via thhe relote and drirectly on the Beocenter 2.
    The Beocenter 2 is set up as AV1 , DVD, Beocenter 2 MK I.
    I have tried to switch to AV3. Same reusult.
    I think the option is 2
  • 01-29-2012 10:05 AM In reply to
    Re: Beocenter 2 - No CD sound. But radio and DVD OK
    Presumably a ML problem; I presume the BC2 is ML connected? It should!
    if you don't have any speakers connected to the BC2 the option should be option 0
  • 01-29-2012 12:03 PM In reply to
    • c1010
    • Not Ranked
    • Posts 14
    Yes, it is ML connected
    The display on both TV and Beocenter is correct (stating CD). It is only the sound that is missing!
  • 01-29-2012 1:32 PM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Is your A.OPT 0 and V.OPT 2? Any sound from headphone socket when using cd command?
