Greetings and thank you for anyone's time to reply.
Will the Terminal 3300 remote will operate a Beomaster 3000?
It looks the most similar to any I have seen.
Is there a recommended facility to repair a Terminal 3000 remote?
Chuck K.
from the states
Unfortunately, although they do look the same, they don't use the same codes.
B&O probably will not want to repair it, but a good/motivated repairman should be able to at least diagnose the fault and maybe repair it. There might be a forum member here who can too!
Excatly. The Terminal 3300 uses the newer codes which are compatibe to Beolink 1000, Beo4, etc.
Beomaster 3000 uses unique codes which are only compatible with Terminal 3000. I got one here: http://www.lifestyle-av.co.uk/product_list.asp?sectionId=4 a few months back.
