Thank you very much for your explanations.
So far my dealer offered me a new B&O panel for > 2000 Euros.
So far I can see the panel is connected via DVI cable and RS232 cable to the Beosystem3. As far as I understood I can connect nearly every panel to the Beosystem 3, there is no need to have a "orginal" B&O (= panasonic panel preprogrammed by B&O) to work with.
Assuming that this is correct, I could for example buy a panasonic panel TH-50PF30ER for 1.750 Euros. This would be cheaper than the offer by B&O and I am sure to have the newest plasma technology on board offered by panasonic currently.
Following the link http://forum.beoworld.org/forums/p/2723/19329.aspx#19329 every panasonic panel can be controlled by the beosystem3 via RS232 (correct ?).
So the question only would be, can I fix the TH-50PF30 within the Beovision9 frame?
The outside dimensions are the same as of TH-50PF10 which are used by B&O (correct ?).
Or do I miss any important point / information?
The problem I have is not only the money, it is the expectation that a 20.000 Euro TV should last longer than 5 years. And I would like to avoid that B&O earns another cent by reparing their low quality sold.
