All Beolab 8000s, old and new, have only one Powerlink connector (there's really no room for another in the connector bay), so you can't directly daisy chain them. But you can get a Powerlink Y adapter / splitter that allows you to do the same thing externally behind the speaker. Both Sounds Heavenly and a B&O dealer should be able to help with that.
