Apologies, I cant speak your language..
The BeoVision 5 is far, far superior product to a BeoVision 8.
Even though the BV5 is some years older than a BV8, its much better quality television.
Despite the age difference, you must remember the BV8 is 'entry-level' B&O product and the BV5 was the TOP range product costing 15,000 Euro even in 2003/4/5
The design of the BV5, the weight of it, the look of it, the quality of it - is much much better than any BV8. The BV8 is cheap plastic product compared to a BV5.
In my opinion, the only TV better than BV5 would be a BeoVision 9...
If you have 5000 Euro for a tv buy a BV9 ~ if you have 1500-2000 Euro buy a BV5. Forget BV8.
Regards,
									    Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
